ZooKeeper won't coin up!
Killert6969
Coram, New York
ZooKeeper wont coin up. In fact the test switches on the inside of the coin door do not work either. All connections have been reseated. The game is fine in attract mode though. What could be causing this?
Coin processor board going bad, if it's still in there that is. If so remove it and have Steph at hobby roms burn you the bypass rom. Mine did crazy stuff until I did it. - Barry
The coin processor board is a small board? Looks like the connections are corroded and one of the resistors looks like it is oozing yellow crap....I will contact Steph
Yes, it's the board mounted off to the side. The coin door harness plugs in one side and the other has a short harness to the pcb. Just pull it out and connect the coin door harness to the pcb. You'll have the short cable left over. I can't remember off the top of my head which rom gets replaced, I want to say 19, but Steph will know. - Barry
Thanks Barry. I placed a custom order with Steph. I hope that does the trick! I am pissed I cannot play my zookeeper. Such a tease to watch it in attract mode!
Cool, I actually hooked mine up wrong after I had the cab gutted and when I reinstalled it none of the coin door stuff worked. I bypassed the board, then it worked but went wacky when I tried to change settings or coin up. I installed the rom and it's been good ever since. Let me know how it works out - Barry
I will definitely let you know what happens...Thanks!
Hey Barry,
I got the rom installed and it sure enough shows 5 credits but neither the player 1 or player two button works? Any ideas?
A couple things to check that I can think of....
Did you get the coin board out of the loop?
Check the connection of the control panel at the panel and the board.
Can you get into test mode? ( I think you can test the inputs there)
When you say you have 5 credits is that because you put 5 credits on it? If not it sounds like the coin processor board is still in the loop...
Let me know, I'm not a ZK expert by any means but I had some trouble getting mine running so I'm happy to try and help - Barry
Barry,
I still have the coin processor board connected. So simply disconnect it? The test switches do not work at all.
Barry,
I bypassed the board. I simply moved the molex connector to the main board that was plugged into the coin processor board. So now it is bypassed.
The connections look fine. I cannot get into test mode what so ever. I say 5 credits because once I installed the rom from hobbyroms, it displays 5 credits all the time now.
I pulled the connected off of the PCB that was for the CP and reseated it. Then zookeeper's player 1 works now but the joystick moves the zookeeper in back and forth. Not up and down. The jump button does not work either??
Mine started doing that, it was an earth problem, check your earth wires.
john
john
Agreed, sounds like a ground problem but the schematic showing the same ground feeding all the switches. The connectors at the pcb are known for problems. I had a voltage issue on my Qix that was solved by fixing the connector. You may also want to pull the control panel and check the grounds there.
Try pulling the connector for the control panel at the pcb and look at the socket as well to make sure it's making connection. Can you use the test switches now? - Barry
Barry,
I wonder if leaving the coin processor board in place and swapping the rom caused a problem? I'm not sure though. I know there are a few people on the boards here with far more knowledge of these boards than I, hopefully more people will chime in. - Barry
Let me add that ZK worked great for one game and then exhibited the issues I last posted. I was thinking that is has to be something with the corrosion on the connectors. any particular way to clean the connector?
The connector's clips were all corroded. Even though I should replace the actual wires as well, I simply replaced all of the clips, reseated them into the molex connector and everything worked! I set the game to free play and played 3 straight games! I was very happy! Also, My Jungle King exhibits a no response from time to time and it is possible it could be the same issue? I will look into it next time that happens.
Thanks Barry and everyone else for getting my zookeeper back to playable condition!
YEAH!!
Replace them. - Barry
YEAH!!
Great! I'm glad to see you got it back working. - Barry
