Zookeeper wiring pics needed, please.
jumpman
Donor 2012
Iowa City, Iowa
I finally have all the parts and a working pcb to fill an empty Taito cab. I have a Zk manual for some reference, but if anyone can provide me with pics of the inside of the cab showing the wire harness and where connections are made. I'm not exactly sure how to hook up the ATX ps to the iso transformer etc.. I'm hoping to dive into this tonight so pics would be greatly appreciated!
if you are using the arcadeshop switcher then nothing ties into the iso transformer....simply tap the switcher into the monitor line and then plug the 2 connectors from the harness into the switcher board..
2 years later I have had pcb repaired, harness re pinned, new atx ps, Taito atx ps adapter, new ribbon cables, coin bypass rom, battery mod.
What hasn't changed is I don't know exactly how to wire the atx ps and I'm not sure where all the connectors from harness go. I have a schematic but since I'm using an atx ps and coin bypass rom I'm not understanding what I need to do. If anyone has the same set up I have and can share some pics of the wiring connections for harness and atx ps would be appreciated.
