Zookeeper Instruction Insert ???
gameguy1957
Mobile, Alabama
Here are some pics for the instruction insert on my Zookeeper. As you can see, it had been taped in place and in one corner the tape came loose. This caused the corner to sag down toward one of the lamps which has baked it into place.
I don't think it has stretched, so I'm thinking that if I can heat it without melting it then it will settle back into place or close enough that it looks decent.
Anyone straightened one of these before or opinions on a way of heating it without destroying it?
Thanks,
-JM
Heat didn't cause it to shrink, but there were some stretched spots on it and it created creases where it couldn't flatten out the extra material at the stretched areas.
Used some card stock to keep it flat against the bezel. This prevents the back lights from shining through, but it's still an improvement over the way it was in there when I got it.
Next step is to see if anyone reproduces it. If not, I'll try scanning it and see what I can print it out on that comes close to the original.
- JM
