zeke's peak / ice cold beer questions
fatherpain
Donor 2024
Fullerton, California
Hi guys,
What size bulb is used for lighting the target holes?
Also regarding the behavior of the ball itself...Ive noticed it takes much more effort to make the ball roll if it is resting on either side bumper...its as if the bumpers are slightly sticky or magnetic...by contrast, if the ball is not touching either of the side bumpers, the slightest joystick translates into movement of the ball. Is this normal behavior when the ball is on the sides?
Thanks,
Tom
I had white pinball rubbers on my bumpers, it stuck, I think the original had flex tubing, try cleaning and waxing the playfield and the ball, mine performs much better now....or take a pic and post it so we can see the bumpers on that. There is an ICB manual on the net somewhere if you search, it will have all bulb types, I wanna say it was a 44 but you might check that......
