Zeke's Peak - Display LEDs, does anyone know which segment of each LED is on top?
Bullwinkle
Rochester, New Hampshire
I'm working on a Zeke's Peak and have an issue with all of the digits. Each one has the top horizontal segment lit at all times (not quite as bright as the others though). In the schematic, the 7 LED segments are labeled A through G. I can see what the possible component failures are with each segment, but it's not readily apparent which segment (A through G) lines up with the top horizontal segment of each digit.
Anyone dealt with ICB or ZP displays that may know this? I suppose I could disable each one individually to map this out if nobody knows this, but I figured I'd ask first.
Thanks..any help is appreciated.
Tom
