Museum of the Game® & International Arcade Museum® Forums
Hi new member and recently purchased a Zaxxon but have to replace the power cord. Looks like the connection point is at the junction box on the front. Trouble is the wires are not color coded except for the green ground so I cannot tell where to connect the hot and neutral wires. The OEM cord was attached to a green wire with a twist connector so that's probably ground, and a blue wire with a twist connector and another looks like it is connected into the 2v fuse which I am assuming this is where to connect the hot wire but I want to make sure so I don't fry anything. The manual on page 40 shows a diagram of the J-box but only lists parts and does not show wiring. Thanks.
