decadentdave
- Joined
- May 28, 2025
- Messages
- 25
- Reaction score
- 5
No slotted screwdriver doesn't work I believe these are cam locks. I turned them until they loosened up but can't get them out. I tried a magnet.Can you use a slotted screwdriver on them? Are they stripped?
That is the insideAre you able to see it from the inside at all?
Yes I have a specific reason. Need to get that panel off. Has nothing to do with the monitor or PCB. Was hoping someone who has done a Zaxxon restoration would know.Is there a reason you want to get down in there? There's nothing there, it's just an empty cavity if memory serves correctly.
On a proper Zaxxon cab, the front folds out to access the guts, and the upper back door gives you access to the monitor.
