Peale
I found a TV with a tube compatible with a G07 (B&K CR-23 adapter), a A48ABH26X.
On measuring the yoke, the horizontal I get 1.6 Ohms, and the vertical I get 12.3 Ohms.
IIRC when doing tube swaps you want to get horizontal readings as close as possible, but vertical can be off within a reasonable amount.
The G07 reads 1.9 Ohms Horizontal, and 52.6 Ohms vertical.
Close enough?
Close enough?
