Yoke impedance issue
gregatron
In Memoriam
Porterville, California
So I get a monitor to repair the other day from a friend. He's having me look at it for a friend of his. His friend bought the monitor from an op for cheap, The op told him it needed a new fly "or something". I finally get around to looking at it and notice that it's a
Kortek K1-2-VOA. But it's stuck on a 25" tube. Everything I can find on this chassis states it's for a 19" tube. For some reason I suspect that it has been hooked up and powered on and didn't work. I checked the yoke resistance and it is 27.4 Ohms on the vert and .9 on the horiz. It seems to be in between hi and low Z yokes. I would call it a high Z though. I hooked the ring tester up to it and the vert tested really low very close to the bad reading.
So I guess my question is, does anyone know what tube a K1-2-VOA chassis is supposed to drive and and is it possible for a yoke to be bad other than shorted or open?
I have quite a few chassis I could replace this with but I believe they are all for low impedance yokes. K7000, Pro Max, A-1 etc...
Is there a way to tell from the chassis what type of yoke it uses?
I have a couple Promax I think that have the values stated on the side but they are for low Z.
Anyone know?
Kortek..
Kortek has a few chasssis that are stamped with K1-2-VO that are different.
Example: I have a K1-2-V0 (stamped on the board) but it's a KTX26. I actually have that monitor out of the cab, so I can give you a yoke reading when I get home if you want. I remember one side being relatively high, but forget the other.
Anyway, even though you have a board with that stamped on it, it could be one of the other "big brothers" to the K1-2-V0. post a pic.
OK, as promised, here are the pics of the chassis in question.
attachment.php
attachment.php
attachment.php
Your model number is right there on that paper label above the flyback controls: KT-2001SF
Casino Tech is the Kortek service center. They recently revamped their website and all tech support manuals are off line.
http://www.casinotech.com/casinotech/tech_docs/crt_docs.html
If you contact them (telephone is best) and tell them what model you have they can email you the service manual/parts list.
Hey Ken, thanks for the link, I saw the label but I couldn't find anything with that number so I went off of the label on the solder side of the board. Do you know if the "20" in the 2001SF means it's for a 19/20" monitor? I just don't wanna hook this thing up to test it and fry the yoke.
I had to go back and look what game the monitor came from. It appears to have been from a Moon Patrol, so that would make it 19"...
you have a burnt ....looks like a resistor on your board from the looks of the top picture. And your vert yoke reading sounds pretty high to me...I'm more used to 6-7 ohms on a vert. yoke with a reading similar to yours on the horz. yoke.
Thanks for checking, that's what I needed to know.
Yeah, I haven't even checked this chassis out yet but I did see that first thing. It's a diode, I checked it on the Huntron and it's still good. Not sure about the yoke though.
