Having trouble getting my yie ar kung fu pcb to sync up with my monitor. I tried the board in a different cabinet and it worked fine. I tried a different board in this cabinet (wwf superstars) and the picture was fine. Looks like a WG monitor, maybe a 4600. Not 100% sure on that. The instruction manual for YAKF says to run a wire to both the -H sync and -V sync. From the composite synce coming off of the jamma harness. I cannot get it to adjust correctly. I even tried to just use 1 sync wire and everything was rolling and would not stop. No matter how far I turned the adjuster knobs. Any ideas? I'm 95,% sure it's a sync issue. Any help would be appreciated. Thanks in advance.
