Yet another Spyhunter sound question
komodo
Donor 2019, 2021
Flower Mound, Texas
This is a Spyhunter I worked on about 3-4 years ago. Apparently there is an issue with certain sounds on the board. When I sold the game the sounds were all fine. (At least I think they were)
Now, the following sounds are corrupted when you play the game or test them individually in the test mode:
Torpedo
CarSplash
Tire Slasher
Smoke Screen
Oil Slick
Does this sound like one of the AY sound chips is bad on the SSIO board or a corrupt ROM? I didn't want to spend too much time chasing the wrong animal. If anyone has any experience in this field I would appreciate it. Searched previous threads for this issue but didn't find anything
SH
There are 2 AY chips on the board. One is for all the sounds you are haveing a problem with and the other is for the car noises, etc. Switch the 2 ay chips around and see if the problem moves to the other sounds. Probably ay chip failing or a connection at the socket.
