sjfreddy
Ok, got a g07-cbo in a ms. pac cab. Game works but the monitor has thin white lines from top to bottom as if the brightness was turned all the way up. When you turn the brightness or focus on the flyback all it does is get blurry. So I have a capkit installed. No change. Then I have a new flyback installed. No change. What should i do next ? Is it possible the tube is bad ?
