XXXX in 1: Control panel, set-up questions
Snarly
New Jersey
Hi,
I have the XXXX in 1 and am overall very happy with it.
I put it in an NBA cab that was converted to Tekken. The control panel has 2 players each with joystick and 4 buttons.
Anyone add 2 more buttons for each player?
What about a track ball - don't really want to cut up the existing control panel. Is there a track ball that could be connected to the pcb and then flat mounted or velcroed to the control panel?
Also, one of the games is Discs of Tron - I would really like this one to work -but do not know if I can configure the controls.
Thanks,
Chris
Get an extension USB cable, a USB trackball and you're all set. While not as responsive for some trackball games as using an optipac and red board trackball, it works pretty well and is easy to hookup
I believe the xxxx in 1 kit should of come with the #5 & 6 buttons adapter for player 1 & 2. I have done two of these. It is pretty straight forward to do. From what I recall, it plugs into the top of the xxxx in 1. Then your run the correct colored wire to your newly installed buttons. You can even daisy chain the ground (black wire) to each new button.
I know one problem is certain cabinets do not have an actual #4 button wired in the jamma harness, it is part of the kick harness. For my Mortal Kombat 2 cabinet, I had to splice in a wire to the Jamma harness and wire it to #4 button, and use the #5 & 6 button harness for those buttons. Prior to that, #4 button was like pressing #5 button.
