I read this thread,
http://forums.arcade-museum.com/showthread.php?t=164711
And after a complete cap kit from Bob my colors are still washed.
What is a good substitute for the 3 in one can cap, Assuming I need replace it next?
I know you can get three separate caps, but how would you wire them in as a substitute?
Also I know you can go up in volts, but how far can you vary uf and still be good if you can't find the exact match? Better higher like volts or lower?
Thanks!
Thanks!
