xm-2001, filter capacitors..
patchboston
Ohio
I'm paranoid. Can anyone just verify that the following mouser caps are what I need to replace the filter caps on my xm-2001 (Red tent) chassis? I know about uf rating and voltage, but last time I ordered caps directly from mouser, it looked as if some were audio grade? I just don't want to screw up again, especially when these caps are over 3.00 a pop!
the pcb calls for:
2x 470uf, 160v
2x 330uf, 160v
so how about..
http://www.mouser.com/ProductDetail...GAEpiMZZMukHu%2bjC5l7YcT9flLFlRvyYunNNIh6eIE=
(what does 12.5Ls mean?)
edit: doh! lead space?
or
http://www.mouser.com/ProductDetail...EpiMZZMukHu%2bjC5l7YW0/d7c/OWn9mnK%2b0GsidI4=
and for 330uf...
http://www.mouser.com/ProductDetail...GAEpiMZZMukHu%2bjC5l7YVqkbz5VVXFdwUSA1SvD7Gw=
http://www.mouser.com/ProductDetail...GAEpiMZZMukHu%2bjC5l7YWyk22/sTEvilrMspoZRJ9g=
Is the physical size the main difference between these caps, or am I missing something?
I'm just looking for a good reliable replacement. Bob Roberts currently sells replacements for about 4.00 ea., a little spendy when I'll be buying of ea for two monitors.
Bob stocks the filter caps for 4 dollars each.
I would just go that route.
I double checked and he does in fact have both you need.
