Xevious voltage and booting
ranchdrsn
Iowa
Need some assistance on where to go from here, have a xevious that displays garbage on the screen and almost seems like it's stuck in a reboot sequence. I get garbled sounds when starting and it wont coin up either. It's running on an arII-02 which I think is ok to do since I'm only using the correct side of the board. It gets a good steady 5v at the board and the ar board was sense modded so it wont compensate for excess voltage drop. The issue did exist before I did the mod to the ar board, so it's not that. I cleaned ALL the socked chips and reflowed the connections. What is strange is where it is suppose to be getting 10.3v it gets approx 12.8. Wondering if this is an issue with the AR? It has not been capped or had the transistors replaced that I know of. Would the excess voltage cause the garbled screen and constant restarting? Hoping someone who has worked on these boards can provide some insight. Thanks in advance.
