Xenon Ramp Pictures
ArcadeTechGW
Donor 5 years: 2012, 2022-2025
A KLOV member asked me to upload pictures of the Xenon pinball ramp.
I figured I'd upload them to the forum, which will save them for posterity.
It's interesting you have a switch that prevents the ball from going back. I believe the original should be the roll back type, but so long as the ball is going down and won't get stuck. This area can definitely be tough to dial in to prevent that stuck ball on the very slow ramp shots that just barely make it up etc. :)
Yes, I just noticed it when you brought this to my attention. mine has a roll back switch/wire.. strange, as I have had many balls not make it all the way through and rolled back down the ramp. given that type of wire, it would get stuck. hmmm... interesting:unsure:
Mine is similar to the one in the photo. Since this switch is just barely on the downhill slope of the ramp - I don't see any real chance of rolling back.
But one thing I have noticed is that his switch actuator is much shorter than mine. At the point in which his ends - mine bends off down towards the tube at about a 20 degree angle, it goes nearly 3/4 across the width of the tube.
