Lindsey
Pin 10 on J3 of the regulator/driver board was toasty black. So bad it snapped in half when I took a closer examination. I'm in the process of wiring up a new connector.
That connector is one of the places that I see overlooked a lot in preventative maintenance work but it's one of the most critical connectors in the game and it's often got problems like the one you're finding now.
There should be good info on pinrepair.com regarding that connector but I would replace the molex header/pins and tie TP1 and TP3 together. That should solve the problem. While you're replacing headers and pins you might as well think about doing J4 on the MPU. I bet it will start booting again once the connector is repaired at the regulator/driver board but it wouldn't hurt.
