XBox coin ops 8
redorlando101
Texas
I have an original Xbox with coinops 8 massive. This xbox has a tsop mod with an SD card acting as it's hard drive. I haven't seen anything like it. It loads very quickly. The disc drive doesn't work to well. I wouldn't rely on it. The SD card is a 125GB. It's has unleashx as it's dash board and the most current XBMC as an additional app. MMAO.
The Xbox will have a collection of original fighting games loaded as well (Soul Calibur, MK series, Dead or alive, etc). I do have others in the works.
I currently have four Xbox's for sale or trade. Two are soft mods and the others are Tsop mods.
that softmod is awesome:
so neat u can play so much stuff - it's amazing
how much for a softmodded xbox?
what is tsop?
A Tsop is a hard mod. It allows the xbox to run without a locked hd among other things. The mod depends on the xbox version. Some versions this can not be done (1.6). For those models you'd need to perform a softmod or install a chip. I have different versions along with different hard drive upgrades. It all depends on what you want. MMAO.
TSOP mod is flashing the bios chip with a modded bios, it's a (pretty much)permanent mod that requires only a couple solder bridges to write enable the bios chip(and a wire jumper for Sharp TSOP chips). WAY easier, cheaper and better than screwing with mod chips.
You still need some form of a softmod to load a dash or tool that can flash said modded bios, but after that it's home free with unlocked drives and whatever you want to do.
http://www.biline.ca/xbox_solder.htm
request for deletion
I'm no longer offering Xbox's due to power supply failures. I have noticed several of my systems that were ready to be sold had poor power supplies and ultimately failed. I've also found faulty caps on the mobo on some of the xbox's. Delete this thread. Thanks everyone. Good luck.
