X-Men no sound, then cap replacement, now sound + static
cr4zymanz0r
Arkansas
So, I took a gamble and bought a 4 player X-Men PCB that was known to not have sound. The sound board had not been tampered with, so I cleaned off the paint with q-tips and rubbing alcohol. Some traces definitely looked corroded.
I removed all the old caps, cleaned everything up the best I could, tested all the traces on top with a multimeter and found around 9 traces that did not have a connection. I got some new caps (non-surface mount for easier installation), repaired the traces, then tested all the connections on the top of a chip with a multimeter. Everything seemed good at that point.
Next I went to test and at first the static was so loud that I couldn't hear any of the game sounds, but after a minute or so nearly all of the static was gone, then after a couple of more minutes came back, but the game sounds were still audible at this point. I poked around at the chip and capacitors with a toothpick while it was running, but that diddn't really seem to change the behavior.
Here's a video I recorded so you can hear for yourself https://www.youtube.com/watch?v=hlDp3euolX4
It sounds more annoying in person than it does in the video.
I know sound issues with these boards are common, but it seems like the main remedy is replacing the leaking caps. Has anybody experienced these static/popping issues after a cap replacement? i'm hoping someone can help pinpoint me to a point of interest such as "oh, that definitely sounds like a loosely connected trace" or "yep, the ____ component is to blame when it sounds like that".
You might have to desolder the chip and look at the bottom to see if the chips/traces on the bottom ones are fine. (That's if all the traces/capacitors are correct on the top)
this. that chip is unique. it actually isn't solid to the base of the board, it's like a double-sided chip hovering in the middle of 2 pillars. that said, if the caps leaked through the traces they can spread down there too. then it gets really nuts.
Now i'm really confused after more testing.
(Note: When I first got the board I tested it to make sure everything but sound worked. Everything else appeared fine, and the sound was silent.)
I decided to start removing capacitors in groups and test after each removal to see if it was any particular set completing a circuit that was causing that static in the sound.
Static remained after each test, even after all the caps were gone. I even removed the wires and such I used to patch the traces. So with no caps it has no regular audio, but still has static hissing and such. Now I'm really confused since that wasn't present when I tested the board prior to removing the caps.
I don't know if the rubbing alcohol toothbrush scrubbing action grazed the bottom of the board a bit too and disturbed a trace that was barely hanging on or what. If anyone knows why it's acting this way let me know
In the mean time, I guess I'll have to start working on the tedious task of desoldering the board. It'll probably be a day before I really have time to start on that task.
EDIT: For clarification, the static only starts once the game has booted past the initial ROM check screen.
Ok, I desoldered the sound board and sure enough there was some corrosion on the underside as well. Luckily it's not near as bad as the top.
Does anybody have a pinout of the bottom of the 054544 sound board? I could've swore I saw one somewhere a week or two ago, but now I can't find it again. I need to verify these traces around the corrosion, but it's not obvious where all of them go just looking at it.
EDIT: Found the pinout I saw before: http://forums.arcade-museum.com/attachment.php?attachmentid=219905&d=1430472756
Tested and found 2 bad traces, and 2 more that had about 10 ohms resistance (not sure if that's enough to be considered bad).
I'll get around to doing the repairs tomorrow, but I debating if I should wait until I get a socket to put the sound board back on the PCB. I'd hate to directly solder all 64 pins back in and possibly still have issues.
FIXED IT!
Repaired the 2 bad traces on the bottom, and went ahead and patched the two with a slight bit of resistance just to be safe.
I got impatient and didn't want to wait for the socket to come in, so I went ahead and soldered the sound board back in since I couldn't find anything else wrong with it. Works fine now :)
Here's some pics I took of the board after the repair. Tiny surface mount soldering is not my strength. http://imgur.com/a/whA12
people on here told me I was a jerkoff for using radial caps.
I was able to save myself the trouble of jumper wires on a Lethal Enforcers I fixed though, using the legs of the caps I went straight to the pins on the edges. the 6-player X-Men (!!!) I did I had no problems with traces. that one went a lot smoother. once again however, radials.
I'm about functionality over aesthetics any day. so sue me. good job fixing it.
FIXED IT!
It looks cool, I like it. Nothing beats the feeling of actually fixing something yourself, especially when you think you're gonna accidentally fuck it all up even worse than when you started.
that's 98% of the thrill of the job.
