Hi,
I just picked up my first X-men six player from Deadpool66 and am just trying to get it back together again after the move.
When I bought it he said that the rear 25" k7000 (the one in the rear box) displayed dark and needed some work. He gave me a backup monitor and board he said that just put on a new cap kit, but hadn't reassembled the monitor. Since I had the help with me, I tried putting the replacement monitor back together and installing it.
Something isn't working right and the replacement monitor isn't powering on (not even a neck glow). The weird thing is that now the machine's other monitor isn't firing up either (although it has a neck glow).
I plan to look through the "common k7000 issues - common repairs" thread to see what I did wrong hooking it up, but my question to the group is whether anybody knows if in a x-men 6-player if one monitor is dead, will the other monitor come up at all or do both monitors need to work to display an image?
If the game should display only when both monitors are connected and have power, then I can assume that I didn't hook up the replacement monitor correctly.
If the game should display regardless if both monitors are connected, then there might be a connection problem on the main PCB.
Thanks for the help
Pete
playchoice.riemen.net
Thanks for the help
Pete
