Hey guys,
I picked this up the other day and just got around to putting it into my NBA Jam cab with a switcher. I powered it up and was greeted by this:
I don't see any obvious cold-solder joints, but I also didn't try to reflow any of the pins. I've powered it up several times a few hours apart with the same result. I also put it into different slots with different harnesses in my switcher, with the same result...and both of the harnesses and slots have been tested with other games. I also went through the reboot by holding down the test button, just for fun, and I got the EEPROM ok message. Thoughts? Should I try reflowing the solder on the pins of the ram? Should I be looking elsewhere? If I need new ram, where should I get it? Thanks!
Derek
Derek
