X-Files Pin - No GI
thefader
South Dakota
My X-Files General Illumination is not working. I checked all the fuses in the back box, and those check out. Where do I look next? Thanks Guys.
how'd y'all check them there fuses out
they can look good but
gotta take them there fuses out and use the continuity test on a multimeter to make sure
even then,
got fooled once when a stranded wire was broken except just enough was attached somehow to test good with the continuity tester but under load couldnt pass enough electrons to run
boy was that a pain to figure out
take a dremel tool with a brass/stainless brush to clean the fuse holders,
sometimes clean the fuses too if im not replacing with new
clean and tight fuse holders are a must
Thanks guys. I did check them all with my meter.. but I'll pop them all out and check the sockets, the board is in good shape, and I'm not seeing any burned connectors. Also all of the voltage LED's are lit up on the driver board..
