wwf RR issue
mrgone
California
last night i was playing my wwf RR and on the 3rd game i noticed that the center ramp stopped registering when you make the ramp shot. it makes the register sound but it does not show the dmd screen to let you know the wrestler has entered the ring and it wont light that wrestlers light. on the 3rd ball all the wrestler lights light up for multi ball as normal. when in multi ball the jackpot light for the center ramp comes on but when you shoot the ramp it does not register the jackpot. any help is greatly appreciated.
Since the sound is not yet working on my WWF, I can't comment on what you are hearing. But I'm guessing that maybe the exit switch at the top of the ramp isn't working. Put the game in switch test mode in the Diagnostics menu and try triggering that upper switch and see if you get anything.
Switches can be extremely flaky. You can push down with your finger and it'll register, while running a ball across it -it won't. Or you can have an "iffy" switch where sometimes it works while other times it won't. The proper thing to do is to put a DMM on it and see if the readings are consistent. If they alter in value or flail the switch should be replaced.
If the switch tests out good then you might simply need to bend the wire contact a smidge.
finally had time today to get to the center ramp issue. a wire came loose at the upper switch on the center ramp.reattached it.everything is working properly.
thank you fellow klov'ers for the help.
