Ok So I cleaned the contacts and adjusted them to what I think the shop manual says to do. So now I can get it to work again except now the Pre Set solenoid gets hot. like red hot. So something isn't quite right? Does anyone have a pic of the "Control Swtich" contacts or a shot of the pre-set/ lock solenoid setup on there Wurly jukebox ( I would think a 24,25,26,or 28 hundred series would be close). I just really need to see or know how that control swtich should look like in a functioning setup. If this helps, when I bought the juke it was setup for free play, and half of the coin mech was gone. I don't know how it's rigged for free play but like I said when I got it you would turn on the machine the select light lights up and stayed on all the time. and it worked great. now I have adjusted the contacts so it's like it was before except now the pre set solenoid gets red hot. I DO not remember how the control swtich contacts were adjusted before I messed with them ( shoulda taken a pic) but I do know that it looks like there are 2 sets of contacts and one by it's self (2 always touching and one open until for select a record then it makes contact to reset the selector....I believe. I really need a pic or the correct on why my pre set solenoid get red hot.
thanks!
