FT - Parts: WTT Nintendo POPEYE kit for MARIO BROS (DK conversion) kit
crassvw
MARICOPA, Arizona
Found a swap, thanks!
mario bros
hi,
I'm not interested in trading for a popeye but I am planning to sell my mario bros conversion setup soon, I'm trying to make sure the PCB works before I do but I have everything, the CP, bezel, marquee, boards, cage, wiring harness and serial plate just in case you're interested. I will get pics if interested as well, I bought it b/c I wanted the DKJR cab for my DKJR setup. I can't get it to boot right now and am trying to troubleshoot it to see if the board is messed up or if I have a wiring/power issue.
Mario Conversion
Hello,
If you don't want to trade or purchase the Mario conversion, let me know. I'm looking for a conversion mario bros. Pictures would be great even if nobody buys. Pictures are fun!
-jot
hi,
Thanks for the offer (you're the third today wanting to sell a MB kit) but right now I'm looking for a swap and not planning to buy one. Feel free to PM jot3 regarding the MB kit :)
....can't get it to boot right now and am trying to troubleshoot it to see if the board is messed up or if I have a wiring/power issue.
If the PS is a DK, it is most likely that. Mario's PS uses a current that is a little lower if I remember correctly. I just know that Popeye has it's own, but CAN use Mario's, Mario uses Mario's, and DKs/VS can all use the same PS.
Hope that helps :)
Hope that helps :)
that's interesting, I wasn't sure the original PS was working so I traded it out for my working dk one to check it and still nothing. I'll put the other one back in and recheck voltages to make sure it's working.
Hope that helps :)
A board will draw the current needed. No issue if a board uses less current than another, it will simply use less. The Popeye PS is actually missing a voltage output so is only good for Popeye. A Popeye board will plug and play with a DK or a Jr I know. Haven't fooled with Mario yet to know for that, if it will power a Popeye, then it will work too.
^bump^ just checking to see if any one is interested....also willing to consider trades for any VS games/pcbs/daughter boards, or NES games :)
Hope that helps :)
DK, DK Jr and Mario Bros. (both conversion and widebody) all use PP7-B power supplies.
I wasn't sure about the widebody Mario but i just checked the manual and sure enough . . .
