WTT: 19" Dynamo cut corner CP w/ Neo Geo layout for SFII layout (US/WV)
shardian
Culloden, West Virginia
I have a 19" Dynamo cabinet with a Neo Geo layout cut corner metal panel. I would like to trade it for a panel with a Street Fighter 2 6 button layout. The CPO is trash on this one.
I'd also be interested in buying a SFII layout panel if no one wants to trade straight up.
Guess you don't like the buttons on an angle? Real easy to add 2 buttons to each side.
I looked this morning, and there is definitely room to add the 2 buttons. I would have bet money there wouldn't have been since they are so close to the front.
If I don't hear from anyone by around 9pm tonight that might want to trade, then this will be my path come this evening. I already have a Greenlee punch set I borrowed from work out in my car. :cool:
I would go ahead and punch it out. I had a CP like that and drilled the holes for the SF2 setup. Not to mention that's not the original Neo-Geo layout but the regular Dynamo "diamond" button layout with an extra hole drilled for the "A" button. I used a holesaw but a punch or step drill should be a lot easier.
I suggest printing out a couple of the 6 button layouts on this page to use as guides. You tape them on your CP drill the pilot hole for the punch and punch away.
You might end up having to move the left joystick a little more over to the left. I did, and in the end it all ended up fitting great.
Moot point now. I went ahead and added the additional holes yesterday. Thanks for the advice Jethro! It was real easy. I wasn't even considering that as a simple solution. I was going to fill everything and start from scratch...
