What does the video out connector look like on a 2049? Standard 5 in a row connector? (R,G,B,Grnd, Sync)
What type of LCD are you wanting to swap out? An arcade LCD or computer/tv LCD?
When I bought my first 2049, it was wired that way (it had a monitor w/ a VGA connector on it). It worked, though came up with a vsync timeout error or something at startup. The game played just fine, but I ended up switching it back to stock wiring (which was still in the cab), then made an adapter from the standard connector to the VGA connector (with one of these: http://www.radioshack.com/product/index.jsp?productId=2102601 ).Lloyd,
You should be able to run a VGA cable direct to the video card and get an image that way. This would bypass the rgb-sync wiring from the jamma harness, and will not be used.
Mike F
Thank you for your help Mike. I haven't worked on a video card before, this should be fun.Btw, I suggested LCD to Greg k when he picked up the 2049 manual at Allentown. I'm interested to see how it looks in a 2049 bezel. He was telling me how those pesky neotecs were giving you hell.
I'm a big fan of LCDs in games for commercial use. They make the games look more modern, and lighter as well. I just did an LCD in a Tokyo drift conversion, in a crusin USA cab. Pulled that old 7500 with massive burn in out of there, and it looks great.
Mike F
http://system16.com/hardware.php?id=784
See where the 2 black things plug into the board, to the left of the hard drive in the picture? That is actually one cord that loops from one part of the boardset to the other. You have to unplug one end (I "think" it is the one closest to the HD in the pic), and that is where you plug in the VGA cord from the LCD monitor.
Or you could do what Dog P says. That harness sounds like a fix as well.
-Mike
-Mike
-Mike
No, you cant just hook the monitor to the video card like a vegas board. The main pcb needs to see the video coming into it or you will get errors. The most simple way is what dogp said, or its also possible to split the vga at the video card and send it to both the pcb and monitor.
Also you may have to change the dip settings, some 2049's came med res.
It actually does work, but at startup, it gives an error about vsync. Nothing that affects gameplay, but I assume there's probably some vsync interrupt or timing thing that doesn't happen.No, you cant just hook the monitor to the video card like a vegas board. The main pcb needs to see the video coming into it or you will get errors. The most simple way is what dogp said, or its also possible to split the vga at the video card and send it to both the pcb and monitor.
Yellow/Black is Ground, and Yellow/White is Composite Sync. So, for the VGA connector, that should be Ground to pin 5 and Composite Sync to pin 13. If it has problems, you may want to also connect the ground to pins 6, 7, 8, and 10... though they're probably internally connected on the monitor. And this also assumes that your monitor can handle Composite Sync (not needing seperate Vertical and Horizontal sync).One more question and I really appreciate the help.
Getting a connector like Dog P suggested.
Pin 1 - Yellow wire/ red stripe
Pin 2 - Yellow wire/ green stripe
Pin 3 - Yellow wire/ blue stripe
What pin or pins does the Yellow wire/ black stripe and Yellow wire white stripe go to ?
Thank you !
LTG![]()
DogP
