WTB: Zaxxon Joystick
I've got the bottom half but no "stick". Looks complete except I don't see any wires coming out of the center hold in the shaft for the trigger. Basically it is the complete lower half with the shaft. LMK
thanks komodo, but I really need the handles with the shaft ... in particular, I need the little plastic piece which holds the led in ...
I have a complete one pulled working from a cab that was converted to a 60-in-1. The little LED on top blinks when you fire, but the little plastic housing around it is missing. As usual, some of the black paint on the grips is worn off.
I'll have to check to see if it still has the connector to the cab's harness or not. I can get pics when I get home if you're interested.
Also pulled and kept the working PCB if you or anyone else needs one...
zaxxon
I have a complete ready to plug and play cp. It has the original flight stick and is in good shape. $40 shipped if you want it. Just let me know.
