did you want AS IS or refurbished?
I saw this hit ebay.. Item number: 280425849106
Actually there isn't much to them. There are two parts that go bad. First if the stick is binding or won't self center, you need to replace the white nylon cup. You can lube it all you want, but once this is worn, the stick won't work right.
Second, the rubber o-ring deteriotes that hits the switches. This can be replaced with a pinball flipper rubber or a standard pinball rubber ring.
Other than that, the rest of the stick is very robust. The nylon cup is the same as what is used in an atari system one game (so they are available).
I went from two sloppy joysticks, to two sticks that are like brand new.
mickey
