WTB: Working Pac-Man PLUS PCB
i have the epoxy sealed pacman plus daughtercard, or whatever it's called, it's ribbon cable, and all the pacman plus roms. but no board, since i took this kit off my setup to convert back to an original pacman. the ribbon cable has one pin loose, it plugs in fine, and it all works. can take a pic if interested...you would need a pacman or ms pacman board though.
but my price is cheap. let me know if this setup will work for you.
Do you need a matching marquee? I have one I can sell you on the cheap! Send me a PM if you're interested..
I have a 100% WATW Pac-Plus PCB. I believe it has the slow chip in it, but I could get ya a fast chip if you wanted it that way. I won't know until tomorrow night whether it's for sale, but if it is - I'll PM ya...
I can sell you a pac plus board with decrypted roms so the black box and ribbon cable is not needed or I can set you up with a standard configuration one.
Klassic - Do you have the directions for the backwards conversion? I have a working Pac-plus but want to try pulling the roms out of a non-working pac board to convert it back to pac-man. Or did you just reverse-engineer the conversion instructions for pac-man plus?
What's to reverse engineer?
Just unplug the Pac Plus daughter epoxyed board and put a Z80 there, then replace the pac-plus roms with pac roms and you're done...
You also need to replace both of the color proms with the original pac / ms. pac color proms - they were different for PAC Plus.
Bill
Mod, you mentioned a pac plus speedup chip. Does one exist? As far as I know the only way to get speedup pac plus is a hardware speedup or something like a 6pac kit.
I think so. I have some extra chips I can check. I figured it was done the same way regular pac/ms. pac was...
