WTB: Whitestar IO board
gobsgraham
AB, Canada
520-5137-64 or -01 I will take either. This is for a Sharkey's Shootout in a warehouse buy so I don't want to spend big bucks on a new one to find out the CPU is shot or there are other major problems with it.
Basically all Sega/Stern games from 96-2005.
The Sharkey's requires a -64 though whiich is just a modified -01. I will see if I can find the schematic for the rottendog one to see if I can figure out how to modify it.
Just received the Rottendog replacement. They say it will drop in without any mods so I called Stern tech support and they also said the the standard -01 Whitestar board will work in it. I am going to put it in the this weekend and hope nothing blows up.
Is there anything I should test or check before I plug this in?
I haven't looked at this in a while but I seem to recall that when I powered it on, the lights come on but nobody's home. There was no lights on the CPU on or anything inside the backbox and nothing happened at all. It looks like most of the fuses are on the IO board so does the CPU get its power through the IO board? or do I have another problem that I should be troubleshooting before I plug this in?
