WTB - WG 4915 Chassis
I own many WG19k4900 and WG19k4915(med res) monitors i'm sure its compatible with the 4900's. I really need 4915 chassis but may be interested in your 4900 chassis, does it work?
The 4915 chassis will NOT work with a 4900 yoke (nor vice versa), and can't be converted easily (one part so far is not available)....
Yep, what he said. To be sure your yoke matches my fully working K4900 chassis, I'd need your ohm readings for vertical and horizontal windings.
And if your 4900 is a standard-res, remember that you can't mix early version chassis/yokes with later version yokes/chassis...
