WTB: Vertical mount frame for a WG k7000 monitor
servo
New York
looking to buy a vertical mount frame for a wells gardner monitor for a Qbert restore. will be using a k7000, game originally came with a 4900. please let me know. my zip code is 11102
The horizontal mount (triangle sides) 19k7000 and 19k4900 frames are similar, but the chassis tray (bottom pieces) are different. However, they can be swapped. The side mounts might have subtle differences, but are functionally the same.
I have seen unique 19k4900 frames for horizontal and vertical mount, but I have never seen a vertical frame for a 19k7000. Typically, it is the triangle side frame mounted sideways for a vertical display. They also made a hoop style 19k7000 horizontal frame, that is similar to the 25k7000 hoop frame, that can be mounted on its side. There was also a skinny/girdle type frame for 19k7000 that was used in dynamo cabs that had room to rotate the monitor.
If a vertical k7000 frames exists, someone please post a pic!
