coinopdirect Member Joined Jan 23, 2009 Messages 501 Reaction score 12 Location Midlothian, Virginia Rating - 100% 8 0 0 Nov 28, 2011 #1 Anyone have the dongles for the CGA / EGA monitors that they could spare? I lost my set and I want to hook up to a CRT instead of VGA.
Maxstang Active member VAPS Joined Apr 12, 2008 Messages 1,236 Reaction score 10 Location California Rating - 100% 24 0 0 Nov 28, 2011 #2 I have some, but you can easily make you're own. Just a parallel plug and one jumper. Done.
Maxstang Active member VAPS Joined Apr 12, 2008 Messages 1,236 Reaction score 10 Location California Rating - 100% 24 0 0 Nov 28, 2011 #3 Actually, you don't even need the dongle. I've used a paper clip to jumper the parallel port in a pinch.
OP OP coinopdirect Member Joined Jan 23, 2009 Messages 501 Reaction score 12 Location Midlothian, Virginia Rating - 100% 8 0 0 Nov 28, 2011 #4 I thought so but I could not remember. Do you remember which pins to short? Maxstang said: Actually, you don't even need the dongle. I've used a paper clip to jumper the parallel port in a pinch. Click to expand...
Maxstang Active member VAPS Joined Apr 12, 2008 Messages 1,236 Reaction score 10 Location California Rating - 100% 24 0 0 Nov 29, 2011 #5 CGA is top row, 3rd pin from the left, as if you were looking at the back of the dongle. *3rd pin to a pin below it. EGA is top row, 2nd pin from the left.
OP OP coinopdirect Member Joined Jan 23, 2009 Messages 501 Reaction score 12 Location Midlothian, Virginia Rating - 100% 8 0 0 Nov 29, 2011 #6 Thank you! Maxstang said: CGA is top row, 3rd pin from the left, as if you were looking at the back of the dongle. *3rd pin to a pin below it. EGA is top row, 2nd pin from the left. Click to expand...
