WTB: Tron ROM set
K3V
Corfu, New York
Can someone burn me a set of Tron ROM's? I definitely need the A9 sound ROM and am trying to clear up the graphics issues seen in the video below. Thanks!
how did you determine it was a rom issue?
I have seen the same issues when the interconnect cables are bad, and when I have just put them on wrong.
I tested the continuity on the interconnects and everything was OK. I definitely need the sound rom (getting an error on boot and worked fine until I powered on with it in backwards accidentally). Probably not a bad idea to replace the interconnects anyways but others have suggested it may be a rom issue.
Those graphic issues most likely are coming from the Video Gen board. Bad staging RAM or bad EPROM socket.
