WTB Tron bits 'n pieces...
keithsarcade
St Peters, Missouri
Pic #1 is the connector that plugs into J3 of the SSIO, its begging to be replaced, very loose and touch sensitive.
Pic #2 & 3 - Both Tron and Satans Hollow have this metal bracket that has a very slight curve (almost flat) that mounts between the glass bezel and flourescent tube cover near the CP. My Tron needs one. Just for reference, I pointed to the part needed that I do have on SH.
Pic #4, just a standard leaf switch that I have mounted to the SH coin door in a fashion that adds credits simply by pushing the coin reject button. Looking for a switch just like it so I can do the same for Tron.
this game has alot of other needs, some of which have already been posted in the WTB section, but for now I want to focus on little things like this, need to take it easy on the pocketbook for awhile, some bills have come up, but I still want to keep busy with this project.
PM me if you have anything. Thanks in advance.
Found a slam switch & leaf switch and may have found the bracket I need. Still looking for the connector. I could care less if its slightly different or missing a key, so long as its a similar connector with wires in the same spots, I can make it work. Anyone have anything close?
