Missing one of the boards in the setare you missing a set or is your set nonworking?
You stil have a cabinet here to put that inI've got a spare Space Zap boardset but not sure if I'd want to let it go.
The space zap specific board?
Which board?Missing one of the boards in the set
He is missing the game logic boardView attachment 809142
So this set does not fill all the slots? This is my mistake then. There are 6 slots that are all labeled with one missing. If this one only uses 5 then we are all set (it's just broken, lol!)and note, there are only 5 boards in that set (not 6)
Didn't realize you posted too - thanks man!So this set does not fill all the slots? This is my mistake then. There are 6 slots that are all labeled with one missing. If this one only uses 5 then we are all set (it's just broken, lol!)
GORF is special with all the "sub" games. Or at least that's what I'm thinking.After reading the write up that Charles Klein did on the space zap boards, I can see that even though Midway marked for six boards, they only used five. So we are no longer looking for this board. When I pulled this cage out of the machine, I was expecting to see a full cage like I've seen on gorf. My mistake.
This is such good material it deserves a STICKY.As the games progressed and evolved, technically, the number of boards increased to support the needs.
The only real difference in configuration is that later games separated the Game and Rom boards into two separate boards whereas the early ones had it combined into one. And the earliest game, Extra Bases, did not use a Pattern board either.
So, for number of boards per game we have:
• Extra Bases = 4
• Space Zap = 5
• Robby Roto = 6
• Wizard of Wor = 6
• Gorf = 6
Also, the boards can be moved around in any order so disregard any labeling sticker on the cage as it's often wrong.
If you need a repair you can DM me.
