WTB: Space Invaders Mother board (Working)
Come on, I know you guys have boards for me... Look through your collections and help me out... Don't want it sitting here much longer not working.. going to scrap it soon.. I will just save the parts for my SID..
I can't believe nobody (in the states at least) has offered one up for sale? I'd sell mine but then I would have to part out my SI cabinet.
CMAC, I know they have them sitting, just don't care to part with it or help I guess, the few that have found are listed as untested boards... in Most cases Untested means it does not work, but you can get more for Untested than for Non working...
Soon mine will go in the fire pit.. I will save the parts for my SID...
I acquired a bunch of SI boards back when I was getting mine up and running. Found out that a couple worked when I finally fixed the power supply.
I lost my notes and don't know which is which and now my SI monitor is shot. I know that one of the sound boards had some missing sounds, but it doesn't help if I can't tell which board is which.
Keep at it. You can test that reset line on the power supply with a voltmeter. It will make a board appear pretty dead if it's not dropping when it should.
K
Kstillin. I have a SID also, tried those boards in my SI and it worked fine.. So it is a main board issue.. If you connect a board to your SI you should still here the some of the sounds, this would tell you they have at least some life and would be better than mine.. lol
Finally was able to buy a Working Space Invaders MB... Thank You Alejandromad.... You made my year.....
