WTB: Smash TV interconnects/cables
JC Arcade
New Jersey
I have the CPU and sound boards, but none of the interconnects and cables. Anyone have a set or know where I can get them?
you can use a mk1/nba jam y unit power cable but you'll need to add a wire for -5 (which is miss-labeled in the manual (+5) at the main pcb)
the ide cable is the same as mk1/2/nbajam/tc/t2/ect...
you'll need a 4 pin connector at j1 on the soundboard with pins 1 and 4 jumpered (hopefully that's there)
(NOTE: Volume pot is not connected at lower left connector (J2) in pic)
attachment.php
(Metal plate is not required).
I'm in need of the power supply cable from the cpu to the sound board, if anyone has it please PM me.
For above snd bds: Ribbon cables or power cablesor replacement volume control & cable--your choice @ $7.50
just use your browsers find function, in chrome it's ctrl + F on a PC then type in any of the above
he does not however carry the jumper at j1
