WTB: Sega Power Supply
zasteeg
Pella, Iowa
Rating - 0%
0   0   0
I am needing a sega power supply for a Star Wars Racer. Model number is: 400-5397-01
Let me know what you have and what shipping would be to Iowa.
Thanks,
zasteeg
power supply
i think you can use a computer power supply on these. check the voltage output on your unit and then google atx computer power supply for the voltages. or if you want a plug and play maybe someone will pop up with one here. hope this helps! good luck!
If it's a big screen game, maybe it uses the same power supply that Sega Water-Ski uses. If it does, I think I have one, but it's not a computer power supply. Do you have a picture of the one you're replacing? I can match it up to mine and see if they're identical.
It's for the 33" screen. I will get a few more pictures up this afternoon. It still works, it just seems like it's dieing because it will work one day and not the next, maybe after I mess with the PSU a few time, clean it off, give it a nice hard elbow.
If a computer supply works that'd be awesome.
Like I said pictures to come.....
I poked around in the game and noticed that the fan on the power supply was not working. I put a new fan from another power supply in and it started up fine. I will check the next few days to see if this fixed the problem.
Let me know if this may not be the problem.
Thanks,
zasteeg
