Mike's Arcade sells the modern Happ version. May or may not be the right one for your coin door (there was a lot of variation back in the day), but worth checking.
I was looking at that part, but I am not sure it's correct since there are no photos from the side. The same part number can be found on Marco Specialties, and it says it is for "entropy" branded Williams coin doors. I sent an inquiry anyway.
Unfortunately those aren't coinco either they have them listed wrong, i have bought some before but not from them, these fit this coin doorSupposedly this website sells them. Never purchased from them tho
https://www.actionpinball.com/parts.php?item=27-1037
They sell the covers separately
Yeah I noticed it had to be paired with that secondary piece of plastic to that makes up the slot so I was skeptical.Unfortunately those aren't coinco either they have them listed wrong, i have bought some before but not from them, these fit this coin door
Williams/Bally Coin Door With Wiring Harness
Williams/Bally coin door for pinball machines. Fits WPC & WPC-95 models. Does not fit Pin2000.www.pinballlife.com
Edit - oops, I should have read all the replies first, sounds like it's sorted and wrong parts weren't ordered.I thought i had sent you those links via PM but i guess i didn't. As far as i can tell they look accurate but unfortunately there's only one true way to tell. You gotta order them.
