WTB: Quantum Wiring Harness
You're best off taking a space duel or other common vector harness, and cutting off the connectors and crimping on new pins in the quantum configuration...
I've done that for 2 quantums... nothing like a nice new connector -- not like the wires themselves are going to go bad.
I may still have some tempest -> quantum adapters left if you want to go that route (but I'd still recomment repinning the tempest PCB end of the harness, and once you've done that you might as well just move the wires around and make it quantum)
did you try emailing dokert? He was going to build some. I think its next up after moon patrol..
if you want to use an existing harness, No need to cut the connectors. Just pop out the pins and put them where you need them.
Probably going to have to go that route. I should have a few harness's around here. Lord knows I've parted out enough Atari XY's with bum cabs.
