WTB Qbert Isolation transformer
houseofpower
Houston, Texas
Need a Gottlieb C-22919 isolation transformer to start new restoration. Will take complete tray like in picture. Unless there is another way to get items powered up. Power in ok, fuses ok, but nothing on the low voltage side.
Your missing fuse F1 in that picture. Those two fuses there are for the main and the monitor I believe. I doubt your transformer is bad. Even if it were its unlikely that all the windings would be bad.
F1 fuse
This pic is from the bottom. I see that the main power cord splits power to the monitor and then to the tray with the isolation transformer. The 2 wires go to the plug ( which is hot ). But thats it. Everything is separate. The silver box on bottom has no power. There is one wire that is wire nutted, maybe it went to the F1 fuse? So I assume I need to drag a 110 power wire from the plug to the silver box?
