Found or No Longer Wanted WTB : Pole Position throttle pulley 039238-01
TastyBoogerz
Donor 4 years: 2020, 2023-2025
Sanger, California
Been doing a light restore on my Pole Position, and realized that the throttle pedal has a micro switch hacked onto it instead of the potentiometer. I was able to source all the other needed parts from Mylstar/aradefixit except for the Pulley.
Haha. The first thing I thought when I read the title was Mylstar. Too bad he's out.
It might be easier to buy a whole used pedal assembly than finding just the pulley, unfortunately.
Or maybe find something via McMaster-Carr (or maybe an RC car/plane catalog, or hobby robotics company) that is close, and modify it manually.
Yeah, I'm 100% open to an entire pedal assembly too. But, my initial search for that has also come up empty.
I have a pedal assembly in my cockpit, I can remove it tomorrow to make sure it has that part. The game works as it should so it should be there but you never know what someone rigged up, 😂. I have already restored another one that will go into the game when the cabinet is done. Pm me if your interested
Let me know if you need my help. As a Machinist, I can spin you up one... I would need detailed dimensions, as my PP cab is 640mi away at the moment... but if you can't find anything, I can fab one up if someone could measure up and sketch
Otherwise, I will be back to mine in April
~Dylan
I have 2 extra sets of pedals from my PP Cockpit refurb. I know one had the same micro switch hack, but I can't remember if the other had the pulley intact. I'll check tonight unless someone else has hooked you up by then.
If anybody local to the SF Bay Area can loan me a pulley or pedal set for a day, I can measure up the pulley to fabricate replacements.
Dylan
I was able to source a full pedal assembly, thank you @angelo0103 !
@journeymandt , thanks for the generous offer! Certainly there does seem to be interest in the pulley and it would be great if that could repro'd.
When you get yours, maybe you could measure it up and zap me a sketch of the pulley? Otherwise, I will wait til April and dig mine out if I can get to it... I have a bunch of games jammed in close in the back of the gameroom. I'll have to shuffle some things around to get to it.
Dylan
