Found or No Longer Wanted WTB - Pole Position EMI Shield PCB
64B1T
Donor 5 years: 2021-2025
Maryland
As in title. Looking for the PCB
A037667
used in Pole Position Board Stacks as an EMI Filter.
But why??
You really don't want to use one in a PP. Especially in a PP. It's just more connectors to drop voltage, because the game board draws so much current.
But why??
For I Robot. They're the same.
PP is rev 01.
I,R is rev 02.
Might be same PCB but different decoupling in BOM?
They're slightly different in terms of what capacitors are populated, and the values, however PP has many more caps installed than I Robot does, so it should just be a matter of swapping them around as necessary.
Asking for a pole position one because I'd be stunned if someone had an I Robot one laying around
Here's what I have. Three 037668-01 (one rev B, two rev C) and one 037431-01 rev A. Unfortunately not a 037667-01 :(.
Well that's a bit embarrassing… all I had to do was flip them over to see different part numbers on the other side. These three are all marked as Pole Position.
