WTB: Pink Wico Joystick
oldfandude
Carrollton, Texas
I am looking for a 3.5" pink wico joystick shaft. I just need the stick with the pink ball on top as I want to switch it out with the the red stick that is in my Ms. Pacman. Anyone?
I can make you one.
This one is 3.5", but I have 4" as well. PM me if interested.
attachment.php
Here's a follow up with a couple of pics. The OP actually wanted a pink knob on a pac stick, which has a skinnier shaft than a standard Wico. I was able to remove the ball from the old pac stick, and then I wrapped the shaft with a thin ring of tape to bulk it up enough to center it in the larger hole of the pink Wico ball, which I removed from a standard Wico.
I inserted the pac shaft into the ball, and filled the hole with epoxy, taking care to get it properly centered, and keep it there while the epoxy cured. The original pac stick had a recessed cavity around where the shaft enters the ball, which was convenient to reproduce with the new ball, as it hides the epoxy somewhat.
Also, the Wico ball is slightly larger than the pac ball, but there was nothing that could really be done about that.
Here are some before and after pics.
attachment.php
attachment.php
