WTB - Outrun Sound PCB, Control Panel, Map
OopsAllBerrys
Donor 2012
Maryland
Rating - 0%
0   0   0
Hello,
I am in need of a working sound amplifier pcb for my Outrun upright cabinet. I've tested the connectors from the main pcb to a pair of computer speakers and get sound.
I am also looking for a new control panel (the gray plastic around the steering wheel and shifter) as mine has some cracks.
Additionally, I need a new map; the one I have is so scratched up.
Thanks!
If you do a google image search I believe you can find the high res image of the map. I had one that was the exact size of the original map. Took it to a printer and had them print me out a high quality sticker. Looks very nice. Suggest semi-gloss, mine is flat and wished I had gone semi gloss. Also if that doesn't float I have another plastic monitor bezel with an pretty good map on it. I would be willing to part with the bezel for a little money.
awesome thanks for the idea, i found the map here http://happycampers.to/arcade/artwork/OutRun Map Decal1.psd.jpg . I'll see if i can get it printed out at Staples or Kinkos on a sticker. Do you happen to have a picture of the map of your extra bezel?
I received a sound amplifier pcb off ebay today; the auction said it was untested but I took a chance. I just hooked it up and it works, now I have sound again :)
I am still looking for a very good condition control panel and map. joearcade, can you post a pic of your map/bezel?
Thanks!
map
This is it only issues is its a bit dirty, corner missing and a small cig burn (from some jackass) came off of a parts outrun machine.
the control panel plastic looks different than mine; i think it came off a different type of Outrun cabinet. The thing that stuck out to me was that there was no plastic on the bottom of the shifter.
I wish that map didnt have a missing corner! I think I am going to give the printout a try while I search for a better map/bezel. I appreciate you taking the pics!
Hey np, my suggestion to you is go to a printing shop have them put it on a semi-glossy durable vinyl with adhesive backing. Get the better material so colors dont fade. Mine cost me 25 dollars.
