Hello KLOV!
I recently grabbed another spare 5 way original Nintendo joystick (used for Super Punch-Out!! exclusively). However, it is missing the small metal bracket that holds the microswitch for the 5th "ducking pull" direction.
In the meantime, @MikesArcade has hooked me up with his reproduction bracket, however, I really would like an original since the original one is mounted differently.
Part # CHSU-11-14 Pull Switch Button Bracket
You can see that the OG version mounts in two small mounting holes that are only drilled into the original Super PO and Arm Wrestling bases.
This part is really useless with any other joystick besides Super PO and Arm Wrestling and yes I know my chances of finding just the bracket by itself are slim to none. But I must try...if you happen to have the bracket let me know and I would buy it from you or trade for it.
