WTB: Ms Pac or Galaga monitor brackets
brackets
If you cannot find any, try cutting the old style metal bed frames for your brackets.
Just cut to length and drill holes(inside wall brackets are a little bigger then the bed frame so you will have to cut the monitor brackets a little longer), and then attach to inside wood and the other brackets attach to monitor. Then attach both together.paint black or silver. Done.
I have a few set mounting bracket,$10 a set+10 shipping.
I do not know what shroud you are looking for ,Is the one mount on monitor bracket,holding the bezel and tinted plaxi glass?
You maybe better off buy new tinted plexi from local glass shop ,hard to find used one in good shape.
Yes, see the pics below for the exact shroud and shroud brackets I need. I can do without the tinted plexiglass piece.
If you have all this stuff, please give me a total of what it would cost shipped to 01119. Thanks!
I have brackets $10 a set and shroud $10 a set ,$15 shipping for the 2.
I may have bezel ,most bezels are not in good shape,cost too much to ship,you maybe better off use new bezel.
